1 - 3 of 3 Posts
I oc'd the processor to 3.95hz at 1.48v. This is all done using the stock cooler. I aslo ran prime 95 and did also run occt for 30mins with the max cpu temps being 61c and the max core temps being 49c. Just wanted everybody's advice on whether to keep it at this oc or to lower the oc.
The cpu and other temps on idle-
337
The cpu and other temps on load-
337
Cpu z validation-
337
Please to let me know what you think of my oc...
The other 50mhz requires a vcore of 1.51v:(...but with regard to temps is my present oc fine? I have an msi board which sometimes scares me but since even after overclocking the tdp isn't more than the rated tdp of the board i should be fine.hopefully:p
1 - 3 of 3 Posts
