Athlon XP 2400+ Specs
726 4
I have been looking for the thermal and voltage specs of the athlon xp 2400+. I am trying to overclock my friend's old rig and I haven't been able to find the maximum thermal and voltage specs. Does anyone have these?
1 - 5 of 5 Posts
· Premium Member
if you look at the chip there is a string of nombers and letters
since its a 2400
the string will have 2400 in it
google that 1 string, it will probably take you to cpu-world
that will show that cpu's spec
· Premium Member
Those are tanks, but they don't oc well.
The Throughbred B Athlon XPs are decent if you have the proper motherboard. Look up your CPU's id to see what core you have (by searching via google).
When it comes to the Athlon XPs for overclocking, the mobile versions are best because the multiplier is unlocked.
1 - 5 of 5 Posts
