1 - 19 of 19 Posts
hi,<br />
<br />
my current pc specs are ASUS A8N-E MB (nForce4 Ultra), AMD Athlon64 3200+, 2x512mb Corsair XMS DDR, Gainward Bliss 6800gs GLH.<br />
I have 2 problems:<br />
<br />
1) i have tried to overclock my cpu/ram, but if i raise the fsb more than 232 it just doesen't boot anymore. i have tried loosening the ram latency and cpu multiplier, but the same problem. if i set the fsb to 233 it just doesen't run anymore. Is this just a physical limitation from my mobo?<br />
<br />
2) i set the fsb to 230 mhz and multiplier to 10x, i restart, i reenter bios, it shows me cpu clock 2300 mgz. Good. i restart again. i let him go into windows...the problem is that here it shows me the fsb to 201mhz instead of 230.<br />
If i set the fsb from windows with AiBooster, it works fine then at 230 mhz... until i restart my computer, when it comes back to 201, even if it is set from bios to 230.<br />
<br />
Can anybody here please tell me why this is happening? <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
perhaps a slight bump on the voltages for both may help. Also check your htt and set it to 4x and make sure AMD cool&quiet is disabled
What is your htt set at, it should be 4x, and make sure your pci/agp bus is locked at 33/66, thermal throttaling is disabled, same with cool/quiet.
Hi and WELCOME Tw33ty <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
Please fill in your "System Specs" via the USER CP at the top of the page, they will show up in every post and help others to help you <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Discussion Starter #5
first thx for info duke <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
cool&quiet is off.<br />
the multiplier is already at 4x.<br />
i have tried raising the voltages to 2.75 @ ram and 1.525 @ CPU and still not working <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /><br />
i am checking now if the pci bus if it's locked ...<br />
EDIT: i don't have a pci bus clock in bios...just a pci express clock which is set to 100mhz<br />
And what is thermal throttling?
Discussion Starter #6
nobody knows..? <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
I have the same mobo and I know there's a PCI lock. Go under the JumperFree Configuration and I think it's the bottom one. It should be set at 33 MHz.
Discussion Starter #8
<div>Originally Posted by <strong>gonX</strong></div>
<div style="font-style:italic;">I have the same mobo and I know there's a PCI lock. Go under the JumperFree Configuration and I think it's the bottom one. It should be set at 33 MHz.</div>
</td>
</tr></table></div>
yes, i have found it...but the problem remains <img alt="" class="inlineimg" src="/images/smilies/mad.gif" style="border:0px solid;" title="Mad">
Make sure you use "Manual" for both RAM settings and CPU settings.<br>
Perhaps a BIOS update and if you have the lates try flashing back down 1 version.
Did you set a divider for the RAM? Sounds like you've exceeded the max speed for the RAM. Look for either fractions (ie. 5/5, 4/5, 2/3, etc.) or DDR speeds (ie. DDR400, DDR333, DDR266). Put a divider on the memory so that it won't run as fast as the fsb and see how it goes from there.
Discussion Starter #11
yes, i have tried with 333 and 266, and lowering the latencies and it's still not working <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Take a look here...<br><a href="http://www.overclock.net/faqs/38169-info-asus-a8n-sli-motherboard-introduction.html" target="_blank">http://www.overclock.net/faqs/38169-...roduction.html</a>
Discussion Starter #13
i have found the problem... i have upgraded the bios and now everything works fine <br />
htt 300 mhz<br />
cpu multiplier 8.5x<br />
htt multiplier 3x<br />
cpu clock 2550 mhz<br />
ram 2-3-3-6 2T<br />
ram divider 2/3<br />
<br />
it's a pretty stable overclock, i have run prime95 for over 2 and a half hours and it's still working. is the oc done well? <br />
the temps are 30-33 degrees idle and ~45 full load.
Goodbye
Sounds good so far, I'd let Prime run for 6 hours to make sure Okay? You might be able to go higher if you set your timings to 3T and drop your muliplier in need be.
If you have some as5 on that hsf you could easily get 2.6 like me <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> I've had it @ 2.75 but it went over 50 a couple of times when my ambient got over 80f in the apartment.<br />
<br />
Shaggyt<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Discussion Starter #16
if i set cpu multiplier to 9x and i run prime95, it fails after 1 minute or the computer restarts without question, even if the temps are ~35degrees <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <br />
so, i think i will leave it like this for now
It's probably RAM related then. The 1/2x effects the CPU speed by 1/2 but not the RAM... so in effect the RAM acts as though you have an 8x.<br>
Put up a screen shot of the RAMS SPD and give us your current RAM settings, perhaps we cah squeeze a little more out of it so you can up to a 9x <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #18
RAM SPD / current RAM settings / current cpu settings<br />
<a href="http://img122.imageshack.us/my.php?image=spdxx3.png" target="_blank"><img src="http://img122.imageshack.us/img122/2660/spdxx3.th.png" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a> <a href="http://img319.imageshack.us/my.php?image=ramsettingsrw9.png" target="_blank"><img src="http://img319.imageshack.us/img319/9565/ramsettingsrw9.th.png" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a> <a href="http://img87.imageshack.us/my.php?image=allsettingsbe0.png" target="_blank"><img src="http://img87.imageshack.us/img87/5192/allsettingsbe0.th.png" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a><br />
<br />
i hope this help, i want to squeeze the best out of my computer <img src="/images/smilies/cool.gif" border="0" alt="" title="Cool" class="inlineimg" /><br />
<br />
EDIT: btw, even if CPU-Z shows that at 133mhz it has 2-2-2-6 latencies, it's specs written on box are 2-3-3-6 (i have managed to get them running @ 2-3-2-6 at the same HTT as now though, even if it wasn't like that when i took the screenshot)
Ok, since it seems to do well @ 200MHz with the extra tight timings, try using the the 3-3-3-8 or even 3-4-4-8 with a default setting of DDR400 and see how high they will go stable with the safe max voltage! You may be supprised <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 19 of 19 Posts
