Hey guys here is some of the OC ready bios for 4850 and 4870 round up! All have been test work perfectly. 3D mark vantage rise by 500mark on hard OC 4850, and 1000Mark on hard OC 4870 ( On my system )
I> 4850 BIOS
1. HD4850 Hard Overclocked. DF Core 750MHz Mem 1100MHz Auto Cool Fan.
GPU Core upper Limit 850MHz
Memory Upper limit 1300MHz
Vcore Modded to 1.175V for hard Overclocking.
LINK
2. HD4850 Light Overclocked. DF Core 700MHz Mem 1000MHz Auto Cool Fan.
Vcore DF 1.12V
LINK
HD4850 only Upper limit. DF Core 625MHz Mem 993MHz Auto Cool Fan.
GPU Core upper Limit 950MHz
Memory Upper limit 1400MHz
Vcore DF 1.12V
LINK
HD4850 only Upper limit. DF Core 625MHz Mem 993MHz.
GPU Core upper Limit 1250MHz
Memory Upper limit 1450MHz
Vcore DF 1.12V
LINK
II - HD4870 Bios.
1. HD4870 Harder Overclocked. Core 825MHz / Mem 1100MHz Auto cool Fan.
GPU Core upper Limit 990MHz
Memory Upper limit 1200MHz YOU CAN EASILY GET UP TO 850/1180 with this BIOS
LINK
2. HD4870 Hard Overclocked. Core 815MHz / Mem 925MHz Auto cool Fan.
GPU Core upper Limit 900MHz
LINK
PLEASE ADD MORE BIOS IF YOU CAN FIND, OR BIOS THAT IS MOD BY YOU!!!
NOTE: ITS BEST TO FLASH YOUR VGA BIOS IN DOS!!
INTRUCTION ON HOW TO FLASH YOUR VGA BIOS IN DOS.
Prepare a USB BOOT. just like the one you use to flash your Mainboard with
Here is how to make a bootable USB drive
1. Make a USB bootable drive using this creator:
USB Boot drive (HPUSBFW)
2. Then download the boot files and extract them to a folder of your choice
3. Run the HPUSBFW program.
Select the correct USB device from the drop-down menu, set file system to FAT32 and check Create a DOS startup disk.
4. Then browse for the extracted boot files (now in the folder of your choice) and press start to begin formating it. DONE |
FLASHING THE CARD
Dowload ATIflash 3.6 here
After you download the ATIflash and The VGA bios need. Copy all of them in to the USBboot and boot to dos.
In dos type this command: atiflash -f -p 0 nameofyourbios.bin "ENTER"
IT WILL ASK YOU TO RESTART ONCE YOU LOG IN TO WIN, JUST RESTART AND TAKE A LOOK IN YOU CCC
THANKS ERICEOD FOR SENDING ME THIS INSTRUCTION!
