ATI 5770...what happpened...
4469 Views 37 Replies 22 Participants Last post by  grunion
Life long ATI user, decided to go for the big guns and buy 2 XFX 5770's Crossfire X. Not an extreme gamer, previously ran my Battlefield 2142 on a Sapphire 3650. Did not look that great but it ran it. Put in the 5770's and game looked just the same, even on high, graphics were gritty, pixeley (<-how do you spell that?) and would not run over 60FPS, bottoming out at 15FPS. Put a single BFG GTX 260OC in and the game ran circles around the pair of 5770's. I just could not stand to play the game like that, I wanted a upgrade from the 3650. Got the 260 from a friend to compare to the 5770's. Everything that I looked at shows that the 5770 should be a way better card. Why would my graphics look so bad. I ran everything on the same settings with both cards. Returned the 5770's and bought 2 BFG GTX 260OC 2 Maxcores. Now im using SLI on the 260OC2 Maxcore's and bottom out at 100FPS with max at 250FPS everything on high. I dont get it. Any thoughts? Are the 260's just that much better?
Status
Not open for further replies.
1 - 20 of 38 Posts
What motherboard did you use?
Did you use a driver cleaner after uninstalling the previous cards?
Evga 750i, no cards installed prior, new build. Latest drivers installed.
lol, mind explaining how you ran Crossfire on an EVGA 750i SLI board?
EDIT: It would obviously explain why you got better performance on a couple GTX 260s in SLI. Because naturally only 1 5770 is going to work on your SLI board. So, the poor performance came from: You game at 1920x1080 / 8xAA, and the 5770 is about on par with 1 4870 1GB. I had the 4870 1GB, and in BF2142, I would max it out in 1920x1080p / 8xAA, and pull around 70-85fps. Hence you getting around ballpark that. Problem solved, brah. It's not the 5770s problem, it's YOU trying to run CF on an SLI board.
Yeah, I'd recommend driver cleaning first. I think the 5xxxs are still using some sort of beta drivers (could be wrong on that one)
But your image quality should improve drastically. Does Bf2142 support CF?
pixellated
Anyways, it's probably due to crappy drivers, the game not being optimized for crossfire,... did you try any other games on them?
And I think you made a bit of a quick decision to swap them for 260's already, now we can't solve your problem with them..
I thought you could crossfire on any board that has multiple slots?
thats your problem the 750i or any nvidia based board does not support crossfire only SLI
EDIT too slow. you need a Intel or AMD chipset to crossfire. Nvidia locks their chipset to SLI
It would be pixelated.
yeah thats correct no x fire on nvidia 750i sli
Originally Posted by dizzyscure1 View Post
cant crossfire on 750i
Yea I realized now, however even with 1 card running, it should have been able to run 2142 maxed out and just as good as a 260.
Also isn't is a big odd that you can run crossfire on a SLI board?
Me as well.
Nope. The chipset has to support it. Only Skulltrail and X5-series and P5-series Intel chipset can do both crossfire and SLI, AFAIK.
Why would Nvidia let its competitor's proprietary technology work on boards using *their* chipset?
Originally Posted by diabolical999 View Post
lol, mind explaining how you ran crossfire on an evga 750i sli board?
:d
That still does not explain why even with 1 card running, it should have been able to run 2142 maxed out and just as good as a 260. And look better than my 3650. Honestly the only difference I saw between the 3650 and 5770 was increase in FPS amd smoothness, the game did not look any better. Why do you guys think that?
Were you running it on the same graphics settings ingame? That would be why it didn't look better. Upgrading your graphics card doesn't instantly make games look better or something.
And we can't explain why the single card didn't perform that well since you already got rid of both the 5770s. We needed to help you troubleshoot them.
No I ran the 3650 on medium and the 5770 on high, and nothing looked any better. The game just did not lag up due to FPS bottoming out at 5-10FPS like the 3650.
It's a bit of an old game.
Your CPU is running stock 2.8GHz too? Bottleneck.
1 - 20 of 38 Posts
Status
