1 - 9 of 9 Posts
my board is capable of crossfire, so i have been thinking about going crossfire to get the full use of the mobo.
i am not looking for top performance, just something i can play a few games at top setting without problem.
i m thinking about these two setup
2 4830
2 4670
will these 2 cards outperform my gts 250? will i score higher in 3dmark06?
If you can, look into two 4770s, though they're hard to find. You can get much more performance for $220.
Not with the 4670s, but the 4830s can hit 20k if only barely.
Discussion Starter · #6 ·
i wona keep this crossfire budget under 150 + able to beat the gts, is that possible?
4850 is only 10 bucks more than the 4830, so either 2 4670 or 2 4850
Originally Posted by Jawwwwsh View Post
the 48xx series xfire will beat your GTS250, but the 4670's will not, they are comparable to a 9600GT so imagine those SLI'd
Actually, two 4670's do beat a GTS250, but only by a small margin.
The 2x4770 would be the way to go, though it may take you awhile to get them.
Here are some benches:
http://www.****************/articles...udget_gaming/4
1 - 9 of 9 Posts
