Does everyone else running primegrid on their ati cards get a full core of cpu usage per gpu. Im checking out now if it affects the time iv already noticed gpu usage seems normal between 90-97% if you force all the gpus to 1 core or not. If it works right i will post the program im using and how to do it.
Locking it to 1 core does not affect the time it seems and lowers the cpu temps and lets you use more cpu cores for other stuff iv uploaded the winafc with the file to limit it to one core for those that have issues. What iv done is i put the folder of winafc in like C:\\ and i made a shortcut of WinAFC.exe and put it in startup so it will work for you even if you forget to load it.
http://www.megaupload.com/?d=ZDJRSKL3
