1. Yes, it will work so long as they are both 4 series cards. The BIOS does not matter as long as CCC recognizes the card as a 4870.
2. A 4870x2 and 4870 in crossfire is basically Tri-Fire 4870's and yes, it will work fine. The 4870x2 will default to 512mb/core, making the total addressable memory space while in crossfire 512mb -- Keep in mind if you are playing at a resolution like 2650x1600, this will not be enough, and you should look into a 4870 1gb version if you wish to Tri-Fire it with a 4870x2.
3. With your new monitor (3007WFP @ 2650x1600) you'll want a 4870x2, Nvidia GTX295, or a SLi combination of dual GTX260s or ATi 4870 1gb cards.
