ATI Radeon HD 5970 - can I run it?
2102 Views 13 Replies 10 Participants Last post by  jpmad4it
Hey,
I'm thinking of getting a Radeon HD 5970, but I read that the minimum PSU is 650W. I currently have a Corsair TX 750W, so I'm thinking I might be OK (not sure if the PSU has the required fittings / leads??)
Also, I have an Antec 1200 case. The cards are said to be 1 foot long! Does anyone have this card in an Antec 1200?
cheers
Jp
1 - 14 of 14 Posts
if will def. fit in a 1200
remember
the hdd cages are removable
your psu is fine =]
You better be fine, I just picked one up for mine. So far, so good.
I had one in my 1200 case for 4 hours before I took it back to the store because of artifacting.
fits perfect.
Also your psu is more than enough.
Fits in my 902 with the middle cage removed.
you are a-ok my friend. that corsair is more than enough
and your 1200 should be a nice home for it as well
I've just seen the prices for these bad boys in the UK and they are pretty steep!!!
What is a decent lower grade card which will obviously improve on my 2 x HIS ATI Radeon HD 4870 512MB? I'm looking to spend around £300.
well you would be able to pick up a 5870 with that much and then some. but they are next to impossible to find. if you can find one though, grab it for sure. should be a nice improvement over 2 4870's if overclocked enough
You are fine i just watched a Video where a guy has 2 5970s on a 850W PSU.
You won't need to remove HDD cage either. It's fits well.
there's one here:
http://cgi.ebay.co.uk/ATI-5870-Gigab...item45ef8defcb
Its about £30 more expensive because they are like gold dust in the UK.
I'm really tempted....but not sure about the Gigabyte GPU brand?
1 - 14 of 14 Posts
