1 - 12 of 12 Posts
Hello<br />
I just ran 3dmark05/3dmark06 with this specs:<br />
P4 3.4 2mb/800mhz<br />
2x512=1gb of 400 ram<br />
Asus board<br />
80gb hd with 7200rpm/16mb cache<br />
400watt case<br />
X800GTO 256mb flased to X850XT SE(stable 550/1200 OC)<br />
<br />
I scored 5849 on 3dmark05, and 1842 on 3dmark06<br />
Is that a good score or low? Can I make it more?
That score seems to be a little low but not really abnormal. With the system in my sig I get 6600 in 3dmark05 with the core at 540 and memory at 612. You can always increase you score by overclocking your card or CPU more.
<tr>
<div>
Originally Posted by <strong>Malaziel</strong>
</div>
<div style="font-style:italic">That score seems to be a little low but not really abnormal. With the system in my sig I get 6600 in 3dmark05 with the core at 540 and memory at 612. You can always increase you score by overclocking your card or CPU more.</div>
</td>
</tr>
</table>
</div>Its 550 core and 600 memory, which is top OC<br />
How did you get 6600?
you should be scoring higher, everybody tells me that the x800 series is more powerful than my 7600gt and you score in the 5000 and i get in the 7000....
Probably my processor. When mine is stock it is about even with your processor but does better in games. With it overclocked to 2.6 ghz it is has the gaming performance that your processor would have at about 3.8-4ghz. Directed at Dex100 Xeoc gets well over 7000 in 3dmark05 with his x850xt and with a volt mod I saw an x850xt pe that scored 8800 in 3dmark05.
Discussion Starter #6
<tr>
<div>
</div>
<div style="font-style:italic">Probably my processor. When mine is stock it is about even with your processor but does better in games. With it overclocked to 2.6 ghz it is has the gaming performance that your processor would have at about 3.8-4ghz. Directed at Dex100 Xeoc gets well over 7000 in 3dmark05 with his x850xt and with a volt mod I saw and x850xt pe that scored 8800 in 3dmark05.</div>
</td>
</tr>
</table>
</div>Well Its not x850xt pe, its just flashed from x800gto. And still 12pipes
Oh, I thought you had the 16 pipes unlocked. If you have 12 then that score is not low at all. That is a very good score for a x800gto.
yes if you only have 12 pipes then those scoresare fine. (even tho i only have 12 pipes <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> lol ) But with new cpu cooler I'll likely hit in the 8000point range, when i scored 7320 points in 3dmark05 i was running at only 2.4ghz and my ram was only at 175mhz. Now that i got a new bios with the clock lock remover I can up my fsb past 300 (and its stable all the way up to 2.8ghz so far just madly overheating but no flexing on the rails of my psu) so at say 2.8ghz I could probably score close to that <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Discussion Starter #9
<tr>
<div>
Originally Posted by <strong>dex100</strong>
</div>
<div style="font-style:italic">yes if you only have 12 pipes then those scoresare fine. (even tho i only have 12 pipes <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> lol ) But with new cpu cooler I'll likely hit in the 8000point range, when i scored 7320 points in 3dmark05 i was running at only 2.4ghz and my ram was only at 175mhz. Now that i got a new bios with the clock lock remover I can up my fsb past 300 (and its stable all the way up to 2.8ghz so far just madly overheating but no flexing on the rails of my psu) so at say 2.8ghz I could probably score close to that <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>Now I got 5983 on 3dmark05 with 567 core and 615 memory<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> <br />
You think its still posible to unlock those 16pipelines on HIS Radeon X800GTO?
Discussion Starter #11
<tr>
<div>
</div>
<div style="font-style:italic">I don't know about the HIS version the only one that I know unlocks is the saphire</div>
</td>
</tr>
</table>
</div>Well, I have tried alot of times to open those 4 extra pipes last year when I bought it, and nothing... Maybe now they have something?
doubtful, if you couldn't do it before it was because the were just not there to get (don't entirely remember the r430 scene but its either the wrong core, in which case you have no chance because the pipes just aren't there or there is a laser cut and then you can't get them either <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> )
1 - 12 of 12 Posts
