Originally Posted by gonX
LOL, I've never experienced any so-called unstable versions of it.
Yep, well, that's just what they call it on
www.techpowerup.com. "Latest stable version"...
Having tried this version now though, I have to say that it isn't picking up on the artefacts caused when I o/c my X800Pro. I can see the artefacts on the fluffy cube, but the program doesn't stop o/c'ing when they appear...
I know my GPU can o/c to about 570MHz before it produced major artefacts, but this version of ATi Tool takes the core over the 570MHz threshold, even though artefacts are clearly visible on the fluffy cube.
I'd check this version out properly before allowing it to auto-find your card's o/c limits, because on my system at least (using the ATi 6.11 drivers) this version of ATi Tool doesn't stop o/c'ing when artefacts start to appear...
And yes, the detect artefacts slider is set to the higher detection/lower overclock setting, so it should definitely be detecting the artefacts and preventing the o/c from going higher....
Don't leave this version unattended in find max core/mem until you see for sure that it is working for you, as this might not be isolated to my system only.
Highly-Annoyed
