1 - 3 of 3 Posts
How do you guys use ATI Tool 0.25 Beta16? I mean do you scan for artifacts or do you raise the core & mem and see if they appear in 3D View without scanning? I have my Asus Extreme 7900GT @ 560Mhz/1600Mhz and it's been like that for months playing games solidly for hours, but as soon as i scan for artifacts they appear straight away, but gaming and 3DMark05 i have no problems whatsoever. Help!?<br />
<br />
Using Coolbits it won't let me go higher than 565Mhz on the core, and memory is as high as coolbits will allow 800Mhz.
Well.. I think the newer versions of ATITool are somewhat buggy, esp. with the artifact scan. If you're fine in games and other 3D stuff, I would not worry too much about it.
Ok, i raised the core to 600Mhz and it halted my system but anything slightly below it is fine...lol
1 - 3 of 3 Posts
