You need to use RadLinker, install that and right click on the desktop, go to RadLinker, and click "set" and "use current" it will give you confirmation notices to tell you it did it.
Originally Posted by simon741 Well in ATI tool I got my new OC higher than ever and I clicked set clock. Turned off my computer then came back and it was back at defaults!!!!!!!!!!!!! How do u get it to save ur clock. I clicked set clock. |
Originally Posted by simon741 NO, is there a way to save it in ATI Tool? |
Originally Posted by Orion14_99 If you want to use ATI tool to save an overclock and load it at the start, do this. 1. Open ATItool 2. Click 'New' 3. Name profile what you want it to be. 4. Set the clock sliders where you want them to be 5. Hit 'Set clock'. 6. Hit 'Save' 7. Hit the 'Settings' button 8. On the drop down menu, scroll down to 'startup' 9. On the first drop down menu on this tab, select what profile you want to use when windows boots. it is set to default, but you can change it to the new profile you just created. 10. Done! |
Originally Posted by timmay7 nailed it ![]() ![]() why the hell should he use one of those noob programs? ATI Tool is the ultimate overclocking program, ya can push it as far as you want to (almost ![]() ![]() |
