1 - 4 of 4 Posts
Hi there everyone.I have an issue with 0.24 version when I oc to xt pe clocks (520/560) then enable the 3D view it goes for about ten seconds and then freezes up and reboot is required.If I set it again to 520/560 and close 3D view it doesn't freeze.If I play games I get excellent performance compared to stock clocks (425/400).FPS goes from a measly 130 up to 175+.Temps go up to 45/50 deg C full load.Artifact scanning is all ok.Has anyone out there had a similar problem with the 3D view playing up like I am getting?.The card I am using is an old crappy ATI Sapphire X800SE agp card.
I think that ATI tool is still beta. I use a program called <a href="http://www.guru3d.com/article/atitraytools/189/" target="_blank">ATI Tray Tool</a>
1 - 4 of 4 Posts
