ATI Tool + Vista x64 + GTX 260?
4033 Views 14 Replies 7 Participants Last post by  BlankThis
Hi guys,
I'm using OCCT to test out my stable overclocks on my GTX 260 core 216 (65nm).
So far I've hit 675/1482/1125 stably for about 5 hours.
I was just wondering if any of you have been able to use ATI Tool with Vista x64 and the GTX 260... I tried a while back and it wouldn't work at all...
rep+ for all help
Jam3s
1 - 15 of 15 Posts
ati tool does not work with the gtx series and vista
Yeah, I figured as much, since it absolutely wouldn't work last time I tried it.
I will stick to OCCT v3.0.1 then
jam3s
I tried with vista, couldnt get it to work, and I have tried 8500gt, 8600gt, 8800gt, 8800gts, 9800gtx+ and no luck anywhere.
Originally Posted by grunion
Sure it works, use this version.
I've used with 260, 280 and my 295.
I've tried 0.27b as well, but I'll try it again.
Thanks grunion
edit: oh wow it works..
It works fine for me in Vista x64 with my 260, you need the beta 3 version, i've still seen people have problems with it though.
ATITool 0.27
EDIT: Beaten to it
with a newer beta too! I didn't even know there was a beta 4
ATITool 0.27
EDIT: Beaten to it
Thanks guys, I tried the 0.27 before and it didn't work but now I guess b4 does
Just doesn't show shader (I'm not sure it ever did?)
jam3s
Nope never shows shader
Don't use it for overclocking anyway, just scanning for artifacts...
yeah I always just used it for artifacts.
OCCT v3.0.1 works well too.
I just wanted a "backup" program, if you know what I mean.
Nice clocks on your 55nm... now I know why people like them so much
I've never used OCCT for stressing a GPU, I should give it a try sometime.
I usualy just use ATITool, FurMark and 3DMark06/Vantage.
Those are just my folding clocks btw, i'm sure with any prolonged gaming I would soon crash
lol furmark scares me... temps are wicked on that thing hahah
lol, yeah me too. It gives you a good idea of what your max temps may be gaming though, since ATItool doesn't really produce much heat
wrong...it works perfectly for me. I run my clocks at 720/1440/1107 and I found my max overclock using ATI Tool to scan for artifacts and windows vista sp1 (32bit).
If I up any of my current settings to the next strap it will produce artifacts in ATI Tool, and it will crash OCCT GPU Test, and Furmark after a certain period of time, while as my stable clocks found with ATI Tool work perfectly and no crashes to date in any benchmark programs, nor gaming.
ATI Tool worsk fine for my 8800GS. It won't display clocks or allow clock adjustments but I can stress test. Same goes for ATI cards as well.
~B~
1 - 15 of 15 Posts
