ATI Tray Tools crashing L4d
732 Views 4 Replies 3 Participants Last post by  Keyzjh
After I installed Ati tray tools, my Left 4 Dead online mode has been crashing (screen turns black and back on and black again).
Before that when I was using CCC 9.2, everything was fine. Is anyone experiencing the same problem as me or is there any other problems that caused the crashing?
1 - 5 of 5 Posts
Sounds like an unstable OC to me. See if it still does it at stock clocks with Ati Tray Tools opened.
It still crashes when i put it at clock speeds 625/1100 MHz.
The only time it didnt crash was when the clocks were at 500/750, which was the 2D mode. Any suggestions of what is causing those blackouts? Thanks.
I have a HD 4850 1GB card btw.
Are you forcing any profiles with ATITrayTools? Sometimes even using AA with ATT can cause problems with the driver.
Nope, I was using stock clocks and only used the fan control settings. The part of ATT i loved the most
edit: on a side note, does rivatuner have the same kind of fan control tweaking like ATT's one?
the one which you can fill in yourself.
1 - 5 of 5 Posts
