1 - 8 of 8 Posts
My wife wants to play NWN2 with me. Her computer is an emachines box:<br />
AMD 3400<br />
Some MSI mobo ati chipset<br />
1gig cheapo ram<br />
Recommended is an ATI X800 or better.<br />
What do you think I should put in the e-box? BTW it's a PCI-e slot. Links would be GREATLY appreciated.<br />
<br />
Thanks!<br />
~BRISK
How much you want to spend on it?<br />
<br />
This would be a good deal... let's hope it's back in stock soon:<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814121031" target="_blank">http://www.newegg.com/Product/Produc...82E16814121031</a>
Reactions: BRISKbaby
<$100 would be nice as she wouldn't use it that often.
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814142061" target="_blank">http://www.newegg.com/Product/Produc...82E16814142061</a><br />
<br />
I wouldn't recomend anything lower than this since the x8xx series doesn't support sm 3.0.<br />
<br />
This is as cheap as it goes for a card that supports all the latest features
Discussion Starter #5
Those are very nice cards! I believe I'll have to wait until newegg restocks that EAX1950PRO. It seems well worth the extra $30 or so. Just a quick question: Is that card better or worse than my 7800gtx?
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814121549" target="_blank">http://www.newegg.com/Product/Produc...82E16814121549</a><br />
<br />
maybe?
<tr>
<div>
Originally Posted by <strong>BRISKbaby</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1383394#post1383394" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Those are very nice cards! I believe I'll have to wait until newegg restocks that EAX1950PRO. It seems well worth the extra $30 or so. Just a quick question: Is that card better or worse than my 7800gtx?</div>
</td>
</tr>
</table>
</div>Better. My X1900GT beats a 7900GT when both are at stock, and X1950Pro is even better, just a hair below a 7950GT. But then if and only if the X1950Pro can't change voltages through software should you go for a X1900GT Rev 1. <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
Discussion Starter #8
<tr>
<div>
Originally Posted by <strong>NuclearCrap</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1383470#post1383470" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Better. My X1900GT beats a 7900GT when both are at stock, and X1950Pro is even better, just a hair below a 7950GT. But then if and only if the X1950Pro can't change voltages through software should you go for a X1900GT Rev 1. <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>I may just pick that bad boy up and change mine out <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> It's kind of sad though. I told myself I'd wait until DX10 came out....<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
1 - 8 of 8 Posts
