1 - 13 of 13 Posts
Which one is Better? <font color="Red">Radeon X1600PRO</font> or <font color="Red">7600GT</font><br />
<br />
Is this any good <a href="http://www.newegg.com/Product/Product.asp?item=N82E16814102019" target="_blank">http://www.newegg.com/Product/Produc...82E16814102019</a>
7600GT. The X1600 Pro makes a good Media Center card, bad gamer card.
<tr>
<div>
Originally Posted by <strong>Namrac</strong>
</div>
<div style="font-style:italic">7600GT. The X1600 Pro makes a good Media Center card, bad gamer card.</div>
</td>
</tr>
</table>
</div>I second that<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<tr>
<div>
</div>
</td>
</tr>
</table>
</div><br />
Most do, but if you get the sapphire x1600pro with gddr3, with a stock overclock..its like the same thing as a x1600xt for 94 bucks.
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>Ch13f121</strong>
</div>
<div style="font-style:italic">Most do, but if you get the sapphire x1600pro with gddr3, with a stock overclock..its like the same thing as a x1600xt for 94 bucks.</div>
</td>
</tr>
</table>
</div><br />
x1600xt is the same as which nVIDIA card?
<tr>
<div>
Originally Posted by <strong>selectodude</strong>
</div>
<div style="font-style:italic">6600GT, i'd say.</div>
</td>
</tr>
</table>
</div>Meh, a little bit higher than that, but it got pretty thoroughly trashed by the 6800GS..
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>Probably a little bit higher......like a 6800XT, or Vanilla 6800.
Discussion Starter #10
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>what about X1650PRO?
The 1650Pro would give the same results as a x1600xt just at a lower price. The 7600GT is the best "budget" card you can get. I got two x1600Pro OC'd Edition GDDR3 and they run smooth however if I had two 7600GT's I would own all games but the DFI board I wanted was xfire only.<br><br>
pink
Go for a 7800gs or gt.....in some cases the 7900gs' are around the same price also....and they are a far better card. Unless you can touch the 1800pro or xt, I would go for a 78, or a 79. They are good cards to mod later when they are closer to being obsolete.
I would say the x1800XT or the x1900GT.
1 - 13 of 13 Posts
