ATI X1800XT Question
520 6
I'm new to attempting to overclock video cards, and had a quick question. According to the stats, the X1800XT is supposed to be clocked at 625mhz core, and 1500mhz memory. When attempting to overclock, it looks like mine runs at 594mhz core, and 1300 mhz memory. Why exactly is that?
I also seem to be unable to overclock even to the levels the card is supposed to default at, let alone anything higher.
1 - 7 of 7 Posts
Yeah, I was using ATI tool. I managed to overclock the card with CCC's overdrive, but I still don't understand why the card runs stock at 600/700, when it's advertised as 625/750.
i beleive that ati tools doesnt have the ability to read the correct information from your card. you could try ati tray tool, though i am not sure it supports the x1800 series yet either. you probably should read the fine print of the overclocking utilites to verify if thats the problem.
The settings that you are seeing are your 2D clock settings, when you play a game it goes into 3D clock settings, that go up to the requested clock speeds that are in you C.C.C., A quick way to test it is to play a game in the middle of a game hit your hotkeys to bring up your C.C.C. while the game is running and you will see that the clocks go up to the posted speeds! have fun!! Slyjerry
1 - 7 of 7 Posts
