1 - 2 of 2 Posts
Hey guys,
I keep running across the following issue on various drivers.
Either I get a full freeze and crash with the error "PAGE_FAULT_IN_NONPAGED_AREA" referencing "atikmdag.sys", or I get the Windows "recovered driver failure" which just goes to desktop.
Happens on various different drivers and i've always done the full cleaning process between installation. The card is completely stock bar a custom fan profile.
The error isn't so often, maybe 2-3 times a week (playing most nights), but do you reckon it could be the card, or is this more likely driver based?
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Sat 16/04/2016 16:59:34 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\041616-6750-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x115531)
Bugcheck code: 0x50 (0xFFFFD00169B71000, 0x0, 0xFFFFF801845B5531, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\WINDOWS\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. PAGE_FAULT_IN_NONPAGED_AREA
1 - 2 of 2 Posts
