1 - 2 of 2 Posts
hey every1.. i just got this new system and im in the process of OCing my x850 crossfire ed & x850xt. i am able to adjust each one individually in atitools version .25 beta 14, but theres a problem w/ the temp display.<br><br>
both cards are on dynamic fan control. the one works just as it should, and shows the temp fine. while the other, once i switch to it under settings, does not show the temp rise at all w/ the 3d window open. im just concerned that since the temp is being displayed at the idle temp (35c which i think is incorrect) that the fan wont speed up and causing unecessary heat. i know that i can just put the fan on a constant % but the noise of these sapphire fans is crazy at 100%.. like a hairdryer lol<br><br>
maybe it is because i am in crossfire mode?<br><br>
so if anyone has a clue, let me know<br><br>
thanks
As far I know, the 3D window in ATITool does not utilize Crossfire properly, since it's not a full screen 3D application.
1 - 2 of 2 Posts
