Attention Samsungers
366 Views 8 Replies 6 Participants Last post by  Crooksy
well i will be purchasing a new monitor soon and have narrowed it down between two
the first one being this
http://www.overclockers.co.uk/showpr...id=949&subcat=
Viewable Area: 22†Widescreen (1680x1050 Resolution)
- Interface: Analog / Digital
- Response Time: 5ms
- 16.7M Colours
- Contrast Ratio: 20,000:1
- Viewing Angle (H/V): 170°/ 160°
- Brightness: 300cd/m2
- 3 Years On-Site Warranty with Samsung
and the second one being this
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 20000:1
- Brightness: 300cd/m²
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 557.3mm x 415.7mm x 218.6mm
- Weight: 4.7kg
- Warranty: 3 Years On-Site
the second one is £1 cheaper, has a higher resolution and is 1" bigger. is there something im missing otherwise this is a no-brainer. will there be a lack of quality in the second.
i will be using gtx260 soon so will i have any problems running games at that resolution?
help is welcome.
1 - 9 of 9 Posts
What are the inputs on the first one? That might be why its roughly the same price.
But full HD won't let you down, go for the second one
I agree, go with the second one. You getter a higher resolution, and it's an inch bigger.
The both have the same connections; 15pin D-SUB, DVI-D
so you don't think the quality will drop at all? (build quality/picture quality)
Second one looks like a winner to me! I don't see why there should be a diff in build quality but I've not owned those models. You could check out some reviews on them.
1080P is a no brainer! Go for the second one!
I would say no the quality will be the same because they are the same model just different sizes. I think that people see 23" as a bit of a misfit, so they probably don't sell many = a lower price.
I went from a 17" to a 24" and its amazing. You'll love it
[/QUOTEhmm yeah i get what you mean. i think ill go for this then, i mean i can always play at a lower res till i get my new card right?
1 - 9 of 9 Posts
