1 - 20 of 35 Posts
hey guys,<br />
<br />
just got my audigy 2 ZS 7.1 soundcard, i have installed all the drivers and correctly installed into the PCI slot, but i still have no sound :S anyone help?<br />
<br />
Anjokid
Discussion Starter #2
Bump, its really important...
goto control panel look for the speaker, see if all the bars are at top if so look for the Soundblaster control panel and do the same.
Discussion Starter #4
yup it is.
Are your speakers plugged in the fourth input from the top?<br />
(or third from the firewire header)
Discussion Starter #6
yep <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Did you use the drivers provided on the cd? Or did you get them of the internet.<br />
<br />
If #1 applies to you, run driver cleaner and try reinstalling some that you get from the internet <img src="/images/smilies/cool.gif" border="0" alt="" title="Cool" class="inlineimg" />
Reactions: rabidgnome229
Try restarting the pc and see if you get a found new hardware message. It may not have installed properly. Also have you disabled onboard audio?
Discussion Starter #9
got them off the new from the creative website<br />
<br />
restarted PC, now changed the PCI slot it was in originally, disabled the onboard too.
Look at it in device manager and see if a question mark is there.
Discussion Starter #11
no question mark.
Do you have a cheap set of speakers to try in it? Are you absolutely sure they are plugged in properly? They should be working unless the card is bad or both pci slots are bad (Are you pci slots locked at 33. they may change with an overclock and could cause problems)
I found this tut on creative forums;<br />
<a href="http://forums.creative.com/creativelabs/board/message?board.id=soundblaster&message.id=46767" target="_blank">http://forums.creative.com/creativel...ssage.id=46767</a><br />
I found a lot of good info in that so give it a good read.
Discussion Starter #14
no pci lock, i am running 333FSB and overclocked using Multi only. if i stick the cable into the Digital input at the top of the soundcard, i get sound from Media player but its all distored and very low. that surely cant be it. i will try sticking the soundcard into another computer to try it out.
Maybe digital only is selected in the creative control panel.
Discussion Starter #16
checked that, maybe its the drivers, can you link me to the drivers?<br />
<br />
also dont know if anything has to do with this, but my HDD just failed more or less, came up explorer.exe caused a error and restarted Explorer.exe, then my visual style changed and then it cut off on me, said on start up primary master failed :S<br />
<br />
anyway got a direct linky to the drivers? maybe i got the wrong ones.
<a href="http://us.creative.com/support/downloads/download.asp?MainCategory=1&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP&region=1&Product_Name=Audigy+2+ZS&Product_ID=4915&modelnumber=&driverlang=1033&OS=10&drivertype=0&x=23&y=10" target="_blank">Here</a> it is.<br />
I don't know what to say about the hard drive, maybe it is just a corupt widows file.
Discussion Starter #18
yup i have them drivers, dunno about the HDD myself, its only just happenend as i have been messing around with the soundcard tbh, hopefully it was just a lil issue and it will resolve itself
Discussion Starter #19
still no sound :mad:
Discussion Starter #20
ok i have been doing some reading up, and apparently if i get the soundcard oem which i have done it wont work i will need the drivers disc for it :mad: or some kind of fix, i am really really annoyed and angry now, if anyone can help me please do, will be appriated a lot!...<br />
<br />
Anjokid<br />
<br />
EDIT: anyone have the extracted drivers, and not the setup? apparently doing it that way works.
1 - 20 of 35 Posts
