Is it possible to use the front panels from the Audigy Platinum with a lower end card, namely an Audigy2 LS? If so any idea if creative even sells then without packaging them with a card?
if your sound card has connectors on it, you can probably hook it up. i don't believe Creative sells front panels by themselves though. i could be wrong, but i checked a couple years ago and couldn't find them.
Yea Creative sells Front Panels by themselves just go to the website. Then go to the X-Fi's and look at the accessories but I don't know if they work with the Audigy. I am debating on getting an Audigy or X-Fi myself, PM me if you have any suggestions.
or you could just decide to not buy a sound card that deliberately doesn't come with standard connectors. there are other choices out there. check these:
