Audigy2 problem
323 Views 2 Replies 1 Participant Last post by  J3r3my
I just bought an Audigy2 ZS from my friend and it sounds great in most games but its having problems with BF1942. It sounds great at first but then the sounds will start cutting out and its like slowly going deaf until I cant hear anything. It works fine if I set it to software or if I use the hardware mode with my onboard sound. I remember hearing someone say that BF1942 doesnt work with Creative cards. Is that true? And any way to fix it?
1 - 3 of 3 Posts
Well I found something that helped...sorta. I set the soundBufferCacheSize from 200 to 400 and it helps but the sounds are messing up sometimes.
Well I finally fixed it after a driver update and some screwing around with the .con files.
1 - 3 of 3 Posts
