1 - 3 of 3 Posts
Im very new to XBMC and HTPC's and have built a machine for the purpose of watching my DVD's from the hard drive (mkv format). I think I have a settings issue, the playback with the audio and video are not in-sync
The audio and video are out of sync around 45-60 seconds into the playback
Here are the spec of the machine
Windows 7 32 bit
AMD Atholon X2 240
2GB memory
ATI Radeon HD 4200
GA-MA785GM-US2H
XBMC version 9.11
What settings should I be looking at to correct the problem?
Is it a problem with the type or quality of the on-board video card?
Do you have a video card you could pop in there? I don't know that much about XBMC, but I would say it sounds codec related.... not sure...
Although i guess if it was a codec it would be out of sync to start and stay that way.... hmmmm
1 - 3 of 3 Posts
