1 - 19 of 19 Posts
First off let me say that I'm not sure if this is the best place to post this but if not let me know.
I want to take the picture below and the one in my avatar & make them into a slide show in my avatar. I will add another pic that I have not taken yet.
Do I need software to do this and if so is there any free applications that will do this.
I have Adobe Photo5.0 shop & Image ready 2.0 but that is hard to use. I remember something like this in the adobe Photo shop but I need to be able to keep the file size small enough so that it will fit into my avatar and I don't remember if it was Photo shop or Image ready...
I'm a total new'b to flash and things of the sort.
Thank you,
N2G
Thanks for the links. Now I'll have to install Photoshop again to see if I can get it working for me.
I wish good Luck to me.
Reactions: N2Gaming
Discussion Starter #5
I may have to try that Hue. I can't seem to get Photoshop to add a new picture as a new layer so that I can transfer the layers over to Image ready for the animation. sigh.
all my Layer options are grayed out w/out the ability to use the tools. Does any one know why this would be?
Can'r hurt, Actually Try finding PSP 6.0. I know that version works fine and is easy.
IIRC PhotoShop had a way of making my head hurt.
Discussion Starter #7
LOL yeah my eyes start hurting after too long. I mean if I could get the layers options figured out then I could move on to the next step in the headache
Discussion Starter #8
Well I figured out what I was doing wrong and how to get layers working. I was trying to open a picture w/Photoshop instead of opening Photoshop then a picture after I had a photoshop file started.
Any way I am able to make all kinds of silly/goofy homegrown avatars now.
Nice work man!
Discussion Starter #10
Thank you.
Discussion Starter #11
I was able to finally make a ASUS MyLogo Screen for the M2N Club seen in my Sig. Check it out and let me know what you think.
Text is far too small.
Discussion Starter #13
Thnx Hue.
What text are you refering to?
My guess would be the Text that says The persuit of performance.
Originally Posted by N2Gaming View Post
Thnx Hue.
Oh, my bad. I thought it was avatar size! I clicked on it and the enlarged version looks great!
BTW I really liked you flipping Quad. Your new one is just irritating.
: hey since your haveing fun with this do you want to take the 2 pics I posted of the TTS in the 939 thread and make me a attack one?
Discussion Starter #15
Oh cool so I can call it a day on the M2N MyLogo.
I was certain my Avatar would get to some one sooner or later.
I'll change it when I take another "well have my GF takes another picture of me on the quad on all fours.
Send me a pm of what you have in mind and I'd be more then happy to pm the results back to you.
Img File size does not matter I can adjust it to fit avatar for you so what ever you have get it over.
N2G
N2G
Discussion Starter #17
I just maid my new avatar between now and my last post just for you.
Wow, your really into gaming!
I couldn't find the pics so don't worry bout it. Gonna play some warlords talk wit ya l8r.
Those are great man!
:applaud :
1 - 19 of 19 Posts
