1 - 5 of 5 Posts
There is tons of programs that do this, which is the best? (freeware/paid)
TMPGenc converts from any file to any file. If you want to convert then burn to DVD then just use the Nero encoder
I use InterVideo WinDVD Creator 3.0. It is quick, easy, and has lots of options. It allows you to make custom menus, and so forth. I highly recommend it. It is payware (free trial probably possible).
Discussion Starter #5
What would a good freeware converter be? I tried "TMPGenc" but it converts it to like m2v or something, and the dvd format has those "video_ts" and audio folders, is there anything that woudl simpy convert it to that?
1 - 5 of 5 Posts
