1 - 3 of 3 Posts
hi im from korea and using an awesome 2500K
My batch is L103A978 and using in a extremely low voltage.
I had stabled in LinX v 0.9.3 10 times.
4.4ghz / 1.2V, 4.5ghz / 1.232v , 4.6ghz / 1.248v , 4.7ghz / 1.288v , 4.8ghz / 1.336v (The 4.7ghz is relevant to 8350K, cpuz bench.)
Is there anyone who is using an overclocked 2500K?
And i am curious about how it costs to buy a used 2500k in your countries.
Also, i had overclocked it to 5.45ghz max, but my mb and air cooling doesnt support the cpu :(
i think it will be able to reach 5.8ghz in 1.7v
Plus) Here is august 1st now :( gonna be really hot
Not New to OCN
You would be wanting to use dry ice or something for cooling it at or near 1.7V, and you should not be surprised if you kill it in the process. Highest I had my old chip was 53x101 at I think 1.56V.
9 Cans of Ravioli
1.7v is way too high even for a 32nm CPU unless you're running sub-ambient LN2/DICE/TEC.
1 - 3 of 3 Posts
