1 - 20 of 495 Posts
Info
While Azza may not be as large of a brand name as NZXT, Cooler Master, etc; they do produce a variety of cases that look great and are excellent quality. In fact they are the only manufacturer I have seen thus far to have a removable motherboard tray that can be configured in either ATX or R-ATX. I know I can't be the only owner out there on OCN, so come on ya'll and post some pictures and get a small community going. This would also provide a good centralized place for anyone looking for ideas or answers about the cases.
Member list
yutzybrian - Genesis 9000B - sold
solar0987 - Solano 1000
InitialDriveGTR - Genesis 9000W
Ecks9T - Genesis 9000B
socketus - Genesis 9000B
DarkHollow - Genesis 9000B
gdesmo - Fusion 4000
Going Mod - Genesis 9000W
BlackIce05 - Genesis 9000B
Korayyy - Solano 1000R
zski320 - Genesis 9000B
sakmeo95 - Genesis 9000B
Jump3r - Genesis 9000B
KONA604 - Genesis 9000B
Tmzasz - Genesis 9000W
TripleTurbo - Genesis 9000W
UNDEADFRIEND - Genesis 9000W
rolandwally83 - Venuz VC701B - (Genesis 9000B)
Sno - Azza Fusion 4000
atled - Genesis 9000W
GeneralKrispy - Genesis 9000W
sporkotica - Genesis 9000W - BUILD LOG
rasa92re - Genesis 9000W
Lionheart1980 - Genesis 9000W - BUILD LOG
Castscythe - Genesis 9000B
RayTheRat - Genesis 9000B
jadepol - Genesis 9000B
ThisisSataaa - Genesis 9000B
fleks - Genesis 9000W
Elmy - Genesis 9000W
Jayrrus - Genesis 9000W - BUILD LOG
i2eal7ired - Genesis 9000B
hat1324 - Azza Z or CSAZ-103 mini-itx
Extra venting in top, credits to DarkHollow!
Link
Pictures of mine
My entire setup
Love this fan controller, little pricey for only 4 channels but at 50W a channel I can run more than one fan off each channel
Kinda orange but looks alright with the build
Modding front bay cover for temperature display
Bottom is inlet, top is for fillport, and side to pump. The fitting with the wire is a temperature sensor
Handy place for a dual pump setup. Mounted with velcro
The liquid tube ports fit a fill port perfect. Score!
Fill 'er up
11
Beautiful case! What is the temperature monitoring display you have toward the bottom of your case? Is that for your GPU?
So you're not using the stock fan controls then, I see. Any reason for that? Do the stock fan buttons only control the LEDs for you now?
If you don't mind, could you also measure the height of the case along the front edge of the top cover? The top curves down on both sides (front and back), and I would like to see how much room it will have under my desk at the very front.
I so wanted that case but i don't know.
I currently have a azza case modded of course in my buildlog
I agree there nice cases!
11
Also, I'm thinking it'd be cool to have an L-shaped window modded in the vented side door, within the protruding square area around the large [screened?] cutout. I don't even know where I'd begin though, as I've never cut metal at home before (once in a machine shop elsewhere).
It's a FrozenCPU water temperature monitor. It has a fitting that is hooked into my 5-way adapter to monitor the water temperature of the loop. Its only about 12F above room temp at the moment (yes I run in Fahrenheit
http://www.frozencpu.com/products/10996/tmp-53/FrozenCPUcom_Custom_Thermal-Star_Bitspower_Liquid_Cooling_Temp_Probe_Display.html?tl=g30c101s457
Correct, I prefer more precise control of the fans (plus I was using more than the built in controller handles). The button pretty much turns the case lights on and off now
It measures 26" at its highest point (about center) and is 25" in the very front
Dremel, drill, masking tape, rivets, and rivet gun. Pretty basic stuff when it comes to window mods
Pics
Still got some work to do but it has to wait till after the foldathon And inc frozen q tvirus ress
ordering it fri!
450
700
700
700
700
700
700
700
Originally Posted by yutzybrian View Post
Very nice. What temps are your Ivy going at? Also I just noticed we have the exact same dual pump setup lol
Heres temps folding on gpu and cpu
at 1.488/1.496 it fluctuates at 4.7
The high temps are when i shut my fans off also
And im prolly gonna buy another one and get the tripple block when i get a new case!
1 - 20 of 495 Posts
