Backup my windows to dvd's?
360 Views 7 Replies 7 Participants Last post by  Gauvenator
Hi I was just wondering if there are any good, free programs that could let me back up my windows, or if possible do a cloning process where I could burn the data to discs so that I could simply restore my windows on a new hard drive if it were to fail without having to reinstall windows and having to deal with getting all the drivers and software again.
1 - 8 of 8 Posts
You sure DVDs are the best option? To back up your sig rig requires 53 DVDs...not something you'll want to deal with later.
Better option is to get a second hard drive, and use Drive Image XML to clone your current install onto it.
Most of the programs you use would compress the data, meaning it would be only a few, though it would depend on what you have installed (I.E how many games).
I know at my moms work, they use a digital cassette tape thingy to backup their files..
I could uninstall all my games, and this is a pretty fresh install so I'm only using about about 20-30 gbs.
It would be easier to use nlite to integrate the drivers with the windows install, so that it should be ready to start installing applications right away.
Most drive imaging/data backup software costs money.
I don't know about a free one but I use Acronis. I just install Windows, install all the programs that are essential to me and then used Acronis to make a free bootable ISO of it and then put it on a thumb drive.
Your best option would be to buy a separate harddrive, install a small linux, and use the "dd" utility to image the entire other harddrive onto the linux one as a .img file. Then you can always boot linux and restore windows if you need to.
1 - 8 of 8 Posts
