I'd been having some fan problems with my Asus 4870 (more details here
http://www.overclock.net/ati/406763-...ld-i-have.html) and decided to try and reflash the bios to see if i could then change the fan settings to something like 0% until 40C.
I used RBE to flash a different bios on and reset my computer (no i didn't backup my original bios
) . Since then i've been unable to get any signal from my card.
I've tried adding another card so that i can get into dos and use ATIflash (can only get my hands on nvidia 8800gtx and 8600gs so i cannot use RBE again from windows) and i've now tried as many bios' as i've found on the internet (10+) but none of them seem to sort the problem out with my card. I always remove the nvidia card from my system but i just get no signal. As far as i can tell, AtiFlash is working fine, it gives me the old and new data after the flash and tells me to reboot to finalise...
Any ideas will be welcomed with kisses
