1 - 13 of 13 Posts
Hey all so I have been playing bc2 for quite sometime now around 4 months. I just recently took advantage of the summer sale and bought the vietnam expansion. I am having issues where the colors are looking washed out not sure if this is intended or not? Also in the vanilla bc2 I have issues where dust/debris especially from explosions are always blocking my view making it impossible to see is there an option to turn or lower these features?
I took some screenshots using steam they aren't high quality but they can give you an idea what i am talking about.
http://steamcommunity.com/profiles/7...4/screenshots/
Also here are my current graphic settings
[Graphics]
Effects=high
Soldiers=high
Vehicles=high
Overgrowth=high
Undergrowth=high
StaticObjects=high
Terrain=high
Shadows=high
Bloom=false
HSAO=true
MSAA=2
Water=high
MainQuality=custom
Texture=high
DxVersion=auto
Aniso=2
Detail=high
RenderAheadLimit=2
Fov=55
Any ideas on what I can ch
The dust and explosions you have to deal with. No way to remove them, sadly. You already have Bloom off so can't really do much more.
Can you take a screenshot and post it (not with steam, like print screen and paste into paint.) Could just be your monitor displaying them that way. I have similar settings and mine looks fine, as long as I set my monitor in the correct mode.
Also I would suggest increasing the Fov to 75 or 90. Seeing more is always useful.
Senior Overclocker
Reduce brightness and increase contrast.
I have them both at 0.5. Everything looks decent.
Hmm what specific things are effected by FOV?
Watercooler
How did you get so many options for graphics? I'm in options i have about 6 options and they are all maxed out with no lag
1 - 13 of 13 Posts
