Can anyone give me a hand with this?
i have the boxed version of the game, and run it through steam, i didn't have performance this bad in SP, only in MP...
My FPS in multi range from 19 to 45, and judging by my system, that shouldn't be happening, is there anything i can do to improve my FPS?
i only play in servers with sub-90 ping, and i have all settings on control by app... running without steam gained me about 10 fps average, but that isnt really much, also, the game runs worse on lower settings than on max :|
Strange. I had problems with my first 4850... Always was artifacting and stuff like that.
Test other games to see if you run into problems, check if the performance is relative to your system on the web. (look for benchmarks with almost exact system spec's are your rig)
I don't get these problems in other games, maybe a tid bit in TF2 but it's not nearly as noticeable, since the fps don't drop nearly as much nor for as long
Reinstall or try some different drivers. Weird issue you are having as my 8800GTS is around the same performance level as your 4850 yet I was able to run WaW maxed fine with 70+ fps most of the time.
Overclock.net
