1 - 5 of 5 Posts
This is the computer in my sig named Rig)2. Computer works fine for awhile, but then wil give a BSOB screen with 0x00000050 stop code. Running memtest on the ram and I believe it is bad. But luckily I can RMA it from newegg. What you guys thing. Sry if pics bad, took with camera phone.<br><a href="http://assets.overclock.net.s3.amazonaws.com/7/7f/7f9f595d_vbattach33629.jpeg"><img src="http://www.overclock.net/image/id/616746/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/e/ef/ef16ab41_vbattach33630.jpeg"><img src="http://www.overclock.net/image/id/616745/width/525/height/525/flags/LL"></a>
well.. memtest says it all <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> what can we possibly add to that.<br />
<br />
Run the individual sticks, so you now who is the culprit.
Reactions: K092084
I figured, was just checking though. Its only 1 stick. So thats easy.
ok <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
Good luck with it
Discussion Starter #5
Ok, Thank you Sir
1 - 5 of 5 Posts
