1 - 9 of 9 Posts
Well With that fan you are gonna get massive amounts of dust in your case and it will eventually make it heat up. Also the AC idea would work but you have to waterproof the crap out of your board because of condensation.
I would deff get a filter. Dust built up in mine before and I almost fried a processor.
That cool air can cause some serious condensation.
Discussion Starter · #9 ·
well sears was out of stock something about it being fall so go figure :withstupi
so i went to lowes an got a 4' pvc cupling and to comp usa to get a 90mm fan and order a fan controler. so im gonna cut out a circle in my window attach the cupling put the fan inside so it will be sucking cool outside air and blowing it onto my heatsink . though that wind pipe might disrupt my case air flow so i might add a out bound fan on top
1 - 9 of 9 Posts
