1 - 20 of 79 Posts
Discussion starter · #1 ·
Dear community,
after I read this article ( http://www.corsair.com/en/blog/bf4-loves-high-speed-memory) , I was sure, because Battlefield 4 will be my main game for the next years: I need to test this out.
Marketing-Gag or truth?
Components
Intel Core i5-2500K S1155 Box
Powercolor HD 7950 V2 mit AMD_Catalyst_13.11_BetaV1
ASUS P8P67 LE (Rev 3.0)
2x1TB Samsung SpinPoint F3 HD103Sj 7200 U/min
3TB FANTEC DB-ALU3e 7200 U/min
128GB Crucial M4 MLC SSD
LG BH10LS30
Corsair TX650 V2 80+
Sharkoon Tauron Green Edition
Mugen 2 Cooler
Windows 8.1 Pro 64bit
(BenQ Xl 2411T 144hz)
overclocks:
i5 2500k @ 4,8ghz
Powercolor HD 7950 V2 @1150 Coreclock with 1,17v , @1400 Memoryclock with 1.58v
RAM:
Kingston ValueRAM DIMM 2x4GB, DDR3-1333, CL9-9-9-24 1.5v(KVR1333D3N9/4G)
G.Skill RipJawsX DIMM Kit 2x4GB, DDR3-2133, CL9-11-10-28-2N 1.65v(F3-17000CL9D-8GBXM)
Testscenario:
Domination Siege of Shanghai, on the roof (see video)
Private Server 1/32 Players, "Scooby Snacks BF4 PCW/CW" http://battlelog.battlefield.com/bf4/en/servers/show/pc/d9788992-49d3-403a-9c9d-b3f1dbce62e1/Scooby-Snacks-BF4-PCW-CW/
Video of the test scenario (short cut of the benchmark, benchmark is 180s long, video is lagging because my hard drive is not fast enough for fraps):
http://youtu.be/GGUlkTA-JII
For every RAM 2 runs.
Ingame settings:
Results:
1333mhz:
2133mhz:
1333mhz vs 2133mhz:
Conclusion
  • less framedrops or less incursions
  • FPS increase 58%, RAM mhz increase 60%
  • -> in cpu-limited situation the fps increase is nearly the same as the ram mhz increase
Extra test on Ultra:
(only one run)
G.Skill 2133mhz vs 1333mhz
Settings:
Results:
  • 13% fps increase overall, 9 more minimum fps, 28 more maximum fps
  • ->even in GPU-limtied situations there is still a good overall increase
2.Extra test on Ultra:
(only one run)
vs.
G.Skill RipJawsX DIMM Kit 2x4GB, DDR3-2133, CL9-10-10-27-1N 1.65v
Downloads:
Excel sheet for low settings:
Vergleich 1333mhz vs 2133mhz.xlsx 23k .xlsx file
Excel sheet for ultra settings.:
Ultra Vergleich GSkill 2133mhz vs GSkill 1333mhz.xlsx 19k .xlsx file
Excel sheet for 2133mhz vs 2133mhz OC (Ultra Settings):
Ultra Gskill 2133mhz vs 2133mhz OC.xlsx 19k .xlsx file
I hope this was helpful for some of you guys. For me the upgrade was totally worth it.
Sincerely,
GamingWiidesire
Thanks for doing this, much more reliable than Corsair testing their own RAM to show how much better this and that is etc.
I got almost the same components as you in the tests so I might just go ahead and upgrade to some cheap 2133MHz-RAM, mainly because of these tests
+REP.
If it is not too much of an issue, will it be possible to test 1600 MHz and 2133 MHz? You could probably just install the 2133 MHz kit and down-clock it to 1600 MHz.
I don't know why I am getting the same results for 1600MHz vs 2800MHz
2560 X 1600 with single GTX780 Ultra settings
Reactions: ricklen
DDR3-1333 is rediculously slow anyway, no wonder you're getting a massive boost.
The highest JEDEC standard is DDR3-2133. You should start comparing from that baseline, and then work your way up to DDR3-2666 or so.
Well, 1333 and 1600 is quite widely used, so it's of interest... especially when past general sentiment was that RAM speeds didn't massively affect frame rates.
Discussion starter · #10 ·
exactly. I also bought 1333mhz ram, because all told me "it doesn't affect framerate, or just by 1-2%"
Discussion starter · #12 ·
Originally Posted by anubis1127 View Post
When were you told that? 1866Mhz has been the "sweet spot" for gaming for the last two years or so.
I bought my 1333mhz ram 2,1 years ago along with my i5 2500k. Back then everyone on "computerbase.de" said go for the cheapest ram, it doesn't matter
You make a valid point. I'd say there's an argument to be made not to go for DDR3-1333 altogether. The absolute price of a DDR3-1866 kit is not that much higher anyway.
On topic, AnandTech did a similar test a while back: http://www.anandtech.com/show/7364/memory-scaling-on-haswell/7. Not that much difference there. Might be just this game.
GPU bottleneck?
Try 1080p
Originally Posted by JSTe View Post
GPU bottleneck?
Try 1080p
but the Corsair blogger used 1920x1200 and 5760x1200 and the differences are so significant.
btw he is using GTX780 in SLI mode while I am on a single 780
I'd like to see a bit more testing from you with 1600 vs 2800. You should see a much bigger difference. Can you retest and maybe check to see where your bottleneck is at the time of testing?
I've got a question because I can't find them in the QVL list.
I just saw these (used):
(Info on the memory module is in the pic)
Will they work on my:
Asus P8P67 PRO?
alright I will use another scene and do a longer test.
1 - 20 of 79 Posts
