1 - 6 of 6 Posts
When trying to connect to a server, it says "Connection to the game server has been lost" and wont let me connect. Ive tried reinstalling, forwarding ports, DMZ, disabling windows firewall. I've even connected directly with the modem, still no go. Any tips on getting this work?
I get the same thing every now and then I usually just turn off the game and just go back it and most the time it works but if it doesn't just leave the game for like 5-10 minutes and it should work.
I wish, Ive been at this for hours =\\
Discussion Starter · #6 ·
Just to reasure you its not a problem with your connection and settings its completely servers side.
Then how are others able to join?
1 - 6 of 6 Posts
