1 - 20 of 39 Posts
BC2 taxes my system. on the missions when your like in the forest/jungle fraps says i get 50 to 70 FPS but its still as choppy as hell. Is this a game problem that will soon be fixed?
Im maxing it out with 8x AA and 16x AF
I notice some clipping and texture pop in from about 5 yards away from my character, but I believe that's the game itself. The new "patch 2" gives me a weird black flicker before loading each new area via cutscene.
agreed.
i have my game forced dxlevel 10 through the game setting file. that helped a tiny bit but still. this game is a TANK. more then crysis on my system
Going into the BFBC2 folder in documents and changing "RenderAheadLimit" to 10 helped smooth things out for me.
Discussion Starter · #6 ·
alright i changed it. what exactly does that do?
yeah the patch has created that issue for me too. i thought patches were supposed to fix stuff...
Discussion Starter · #8 ·
yeah no idea lol. funny thing though multiplayer is perfectly smooth for me
This game isnt as polished as once thought. but they will be fixing it
I heard you were dead...
That's OK. If I use any more than 2x MSAA in the game menu (not forced in my drivers) then I get random black squares popping up all over the place. However, with 24x edge-detect AA and 16x AF and whatever that advanced AA is forced in my drivers I get better frame rates and no black square problem...
yeah thats a game problem
well both campaign and mutliplayer are really smooth for me. and i'm playing maxed out settings. maybe i have a golden computer lmao
I get a steady 70-80 FPS with 16xAF and 8xAA and that weird HAO(?) lighting enabled with everything on high. For some reason, V-Sync won't limit my FPS to 60. Dunno why. I'm gonna try that smoothing thing and see if it helps any.
Edit: Didn't help... Oh well.
Originally Posted by mocha989 View Post
why would i get ati cards?
Because they are "Better" or "Better Value"
I dont believe so but what ever.
I was looking at your stats. Thats very Odd i would have thought those cards were sufficient.
Now if i recall from when i had the beta i believe Nvidia released a update which allowed BC2 to use SLI.
I remeber this because i had horrible performance untill i updated.
Try updating your Nvidia software.
Discussion Starter · #19 ·
i have hte most recent WHQLs. the ones that supposivly cause cards to overheat but i havent noticed a single problem
1 - 20 of 39 Posts
