1 - 4 of 4 Posts
So I just started playing this game again and I have a problem already. I can;t connect to server, just comes up with the failing error.
I've had a look around for the punk buster self update and used it and it still doesn't work.
Does anyone know what to do? I don't really wanna uninstall and install again because it'll take a while.
Thanks BMorrisSly
Originally Posted by XNine;11986778
Did you restart after the punkbuster update? Have you updated the Game as well?
It's through Steam so it automatically updates, I'll try searching for updates through steam. Yeah I did restart although nothing has changed as far as yet. I click play now also and it just connects me to an empty server. Now that I updated punkbuster it doesn't do that anymore.
EDIT: Now everytime I launch it, it says in the bottom right hand corner (steam) Battlefield BC2 has finished downloading...
It says that for me too. Make sure when you're browsing servers "EA SERVERS" is NOT checked. If it searches for EA servers, most of the time it won't find anything. Also, make sure that Punk Buster servers are checked.
1 - 4 of 4 Posts
