1 - 12 of 12 Posts
So if i use a bclk of 100 4.2 ghz my ram is set to 1806
if i use a bclk of 200 my ram is set to 1600 4.2 ghz
is it better to have the faster ram or the higher bclk for PERFORMANCE
i can easily go back to 1806 and drop the bclk to 100 or so and have the ram set to 7 7 7 24 1t
semi-legit
Wait, can't you use a 10x memory divider?
If you're at 200BLCK and RAM is 1600MHz you're using 8x; bump it to 10x and you'll have 2000MHz.
Regarding clocks vs timings: with the IMC on Nehalem chips; frequency > latency, so having 2000MHz CAS9 would be more beneficial than 1800MHz CAS7.
yes but the ram is never stable at 2000 ever
we have tried everything not possible which is why i am at 1806
semi-legit
Wow really? Which kit is that CAS9 or CAS8?
Did you try loosening the timings / upping the volts a bit as well?
Given how much those kits cost, I'd actually send it back to Corsair if it can't run at stock settings...
Discussion Starter #5
nope can't run at stock
cas 8
and its not the ram because the ram works fine at anything besides 2000
1906 runs fine for about 6 hours
no issues running 1806 and anything below 24 hours testing
semi-legit
Well if it's not the RAM it's the board; and that board should have NO problem reading 2000MHz RAM...
At least it's the CAS8 set though; maybe try 2000MHz w/ 9-9-9-24 / voltage bump if you need (EDIT: guess you may have tried that
If you're fine with running it at 1806 / tighter timings fine (you're not going to notice any difference in gaming), it's really other applications / benching where you'd really want to have the 200MHz over timings.
Discussion Starter #8
tried that to nothing
right now i am at 7 7 7 24 1t 1806
good?
semi-legit
Well yea looks darn good
Again so long as you don't mind the fact you're not hitting 2000MHz it's not going to be a very noticeable (if at all) difference in your games etc.
Discussion Starter #10
i am guessing its the ram
my 1866 back on my rampage 2 and 920 did 1900 or a little above no issues
these sticks have issues
also i seen others with the same issues as well
anyway
you think the ram can go even lower if so suggestions?
because 6 6 6 24 does not boot at all
semi-legit
The lowered CAS isn't going to make much of a difference as opposed to what you have now.
Again with the Integrated Memory Controller, latency is greatly reduced already so tighter timings don't yield as much of a benefit as upping frequency.
1 - 12 of 12 Posts
