Hi.
Welcome to OCN.
Your cart looks pretty good.
If you are open to suggestions, you might want to consider running distilled water and some biocide in lieu of the Feser... it is less expensive, and as a first-timer you may need to drain, and re-fill. Using a less expensive liquid might save you some money.
Also, You may want to get direct feed-back from some users that have tried the Koolance block...
Also, there were some issues with Yate Loon knock-offs, so you may want to find a verifiable way to ensure that you are getting the real thing.
Additionally, There are some 360 rads that might perform better than the Swiftech so if you are open to suggestions, let us know.
Whichever path you choose, I think that you will be quite pleased with a liquid cooling setup.
Good luck.
