>>Ok I have manually set the ram to ddr 533mhz, idk whta 1:1.66 meansi ddint see no options with that number involved.
They're both the same thing, some motherboards have ratios and others just have the speed @ 200mhz FSB. At an FSB of 240 your memory will run at 400mhz with this divider, but underclocking it some generally will not effect performance especially in things like gaming (that mostly has to do with the processor frequency)
>>As for the HT/NB multipliers im slightly confused, i have found what i think >>is the multiplier option titled CPU NB Mutliplier: has options of 5x-9x. I also >>see under the Chipset tab options for K8 <->NB HT SPEED: >>200,400,600,800mhz,1,1.2,1.4,1.6ghz Also K8<->NB HT WIDTH >>downarrow8uparrow8 or down16up16.
CPU NB Mutliplier: has options of 5x-9x <-- you want this at 7-8x when the fsb is greater than 200mhz... if it goes slightly over the stock rating at 8x (like 1840mhz or something) you should be fine, it's just when it starts to go over 1900mhz things can get iffy unless you have a 750 southbridge which your motherboard doesn't. This doesn't actually have much bearing on performance though so long as it's not less than 1600mhz or so.
K8 <->NB HT SPEED: >>200,400,600,800mhz,1,1.2,1.4,1.6ghz <-- You want this at 1.6ghz unless you can get it stable at auto (mine gets buggy as hell when the HT goes over 2000mhz)
Also K8<->NB HT WIDTH >>downarrow8uparrow8 or down16up16. <-- should be 16/16.
>>So is this all ok? Prime has been running bout 15min no errors, but i do notice all the cores will
>>not finish test at the same time, is this normal? Noticed even though i input 230 in bios is
>>showing as 231?
Yes, this is normal on both counts, cores finish the tests all at different rates, and sometimes motherboards will automatically change the FSB one mhz up or down for stability reasons. Mine only allows even FSBs.
It's looking better though.. You should be fine to push the FSB now and figure out the maximum overclock you can achieve at the voltages your cooler can handle =)
edit: I just realized that 533mhz was the wrong divider! 1:1.66 is what you want which is 667mhz on the mobo. This will let you get 400mhz @ 240mhz fsb, sorry. 533 is actually 1:1.33. I found that an FSB of 240mhz was where my athlon X2 was happiest, and the memory ran at the right speed and the system was the most stable, but I don't know if that extends to phenoms.
