http://www.behardware.com/news/12153/asus-hd-7950-directcu-ii-fault-report.html
The Radeon HD 7950 DirectCU II from Asus, only just available in stores, suffers from a fault with the fixture for its cooler that makes the GPU heat up and can rapidly lead to crashes, especially if you're overclocking your GPU. We recommend you to avoid this model while waiting for Asus to correct the problem and recall the faulty batches.
