1 - 3 of 3 Posts
i seem to be having trouble on my pc with certain benchmark programs.<br />
<br />
3dmark 03 worked fine <a href="http://service.futuremark.com/orb/resultanalyzer.jsp?projectType=10&XLID=0&UID=6787923" target="_blank">http://service.futuremark.com/orb/re...=0&UID=6787923</a><br />
<br />
thats my score stock btw.<br />
<br />
but 05 has like a 3d pixel problem :S and aqua mark 3 crashes right before the scoring.<br />
<br />
i tried installing vista on my second partition. and aquamark didnt crash. but the 05 problem still happened :S<br />
<br />
any ideas? using 6.10 cat and 6.9 cat both have same problems.<br />
<br />
il post the exact errors in a minute.<br />
<br />
edit: oddly "this time" 05 worked <a href="http://service.futuremark.com/orb/resultanalyzer.jsp?projectType=13&XLID=0&UID=6788043" target="_blank">http://service.futuremark.com/orb/re...=0&UID=6788043</a> o_O anyone have any ideas whats going on here :S ? now time to try aqua mark Oo<br />
<br />
edit here is the error im geting on future mark3:<br />
<br />
help :S ???<br />
<br />
<br />
edit: i should have seached >.> i found what was wrong <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /> i needed a patched dll file for ati cards <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> lol this can be closed or deleted <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br><a href="http://assets.overclock.net.s3.amazonaws.com/f/f4/f4ba2cc6_vbattach34228.bmp"><img src="http://www.overclock.net/image/id/616266/width/525/height/525/flags/LL"></a>
Administrator
Have you tried reinstalling your drivers or updating them by doing this below : <br />
<br />
''INTEL HYPERTHREADING'' Can help make Applications in Windows XP run faster!!! With all the new Current INTEL CPU'S and some of the older ones there is a Feature called HYPERTHREADING which when enabled alows the CPU to execute two threads of the smae application to open it faster. Unfortunately HYPERTHREADING technonlogy is only currently supported in Windows XP. To make sure you can have INTEL HYPERTHREADING TECHNOLOGY enabled please check this FAQ: <a href="http://www.overclock.net/faqs/74989-...u-got-its.html" target="_blank">http://www.overclock.net/faqs/74989-...u-got-its.html</a> <br />
<br />
51.Installing Graphic card driver efficiently!!! When you Update your graphics cards drivers theres ways that you should go about it. Follow these simple steps below. <br />
<br />
1.Download and install ''Driver Cleaner'' Here:<br />
<a href="http://www.drivercleaner.net/professional.html" target="_blank">http://www.drivercleaner.net/professional.html</a><br />
2.Uninstall your Current Display drivers such as your ''ATI'' or ''Nvidia'' drivers. <br />
3.Now run ''Driver cleaner'' and depending on the Drivers you have you will have to select either ''ATI'' or ''Nvidia'' from the drop down menu. Only select the main title of the driver in the drop down such as just ''ATI'' or ''Nvidia''<br />
4.Once you have selected Your driver click on the ''Start'' button and this will now start the driver cleaning process. ( Do this twice to be sure ) <br />
5.Now reboot your system and Download the latest Nvidia or ATI and go ahead and install them. <br />
<br />
Doing this avoids driver corruption and conflicts so you can now enjoy smooth gameplay.
Just for folks having the Aquamark problem, here is the patched .dll
1 - 3 of 3 Posts
