stick with wired connection...too much overheads associated with wireless.
To answer your question simply: No.Originally Posted by mothrpe;14199622
Hi All,
I have my sig rig connected directly to my rogers cable modem as it is the only pc at my place.
That said, are there any benefits to using a router with this connection anyway? I mean peformance wise.
Very good point. Security. Hardware firewall and NAT are 2 benefits of a router. I'm not sure if your current modem has a NAT though...Originally Posted by newphase;14199689
Use a router (NAT firewall etc - infinitely better than crappy software f'wall)
Stay wired, though. (I hate wireless)![]()
This x 1000Originally Posted by Balthazor;14199813
You'll notice if you directly connect a computer or put it into a DMZ that it will almost certainly be subject to probes and port scans by hacking bots constantly.
Using a router allows it to effectively be your decoy. One of your best lines of defense is to take advantage of a router's NAT.
You'll be less likely to have a compromised system, and THIS is a significant performance advantage.
Solution: Get a better routerOriginally Posted by -Allen-;14199840
No! In fact, it may be even worse. 2 weeks ago I found out that the slightly old router I have have limited my advertised 10mpbs connection to 6.6mpbs. When I called Rogers, they told me that it was the router, and when using a direct connection I actually had 20mpbs! 2x the advertised rate.
Most cable modems do not have NATs, they simply pass all traffic through to the ethernet port.Originally Posted by Boyboyd;14199717
