What is your maximum budget?
around the cost of Macbook/Macbook pro.
What country are you in?
Hong Kong
What will be the uses of this laptop?
Minor: photoshop, video edit (basic)
Heavy: Multitasking, music, videos, work (word/powerpoint/excel), photography, web surfing.
Do you have brand loyalty or care which brands we select for you?
Open to Anything, please no Alienware btw.
What screen size do you require?
13 to 14.
What screen resolution do you require?
The higher the better, apple's 1280 x 800 is fine.
Are you looking to buy NEW or would refurbished/recertified/used be okay?
New.
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet)
around the life of a Macbook/Macbook pro
What games would you like to play with your laptop? And on what settings?
No games.
What operating system do you need? (if any)
Windows 7 or Mac
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.)
Anything within the Black and white spectrum. I would prefer a smart black or the Mac style silver, titanium grey is fine too. Something not too girly
And something thats not a dust magnet.
How much hard drive space do you need?
at least 250GB.
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.)
Webcam, firewire for backups.
Is there anything else we need to know?
it needs to be as light as the Macbook/Macbook pro
as thin (little bit over is fine) as the Macbook/Macbook pro
reliability!
cannot run overly hot and burn my lap.
no ssd because its too expensive
Thanks in advance.
Hong Kong
13 to 14.
New.
No games.
Windows 7 or Mac
at least 250GB.
reliability!
Thanks in advance.
