1 - 20 of 35 Posts
Originally Posted by musicPC View Post
If you don't care about size, The M-audio AV40's.
might have a hard time putting them on my desk.. i will try though.
Hows the bass on those? i LOVE my bass
Discussion Starter #6
i only buy from amazon/newegg and SOMETIMES in stores if its cheap
Klipsch Pro Media 2.1 is $179 on amazon and out of stock at newegg (deactivated)
M-audio AV40 is $121 on amazon, $179 on newegg
Hmmm...the bass is good, but like i said. They are bulky, i can recommend something different.
Go for it :)
i will seriously consider those though.
Gigaworks T40's.
Discussion Starter #9
Originally Posted by Thingamajig View Post
Gigaworks T40's.
most likley not, remember i said 2.1, and those only go to 50hz
Discussion Starter #10
and @music pc, those are small speakers:) ive got much bigger ones on a desk in my basement... (24 inches..)
Look Im really into audio and Speaker's and know alot about them. I my self had the Logitech Z 2300 and I knew they weren't the best... I then had about $1000 to spend on speakers and finally got what i wanted for years.. However the point is that for under $150 the Z 2300 is a great deal!! You get a high volume and good bass with okay highs and mids for under $150 go with the Z 2300 and work your way up from there.
Discussion Starter #13
Originally Posted by azianai View Post
Harmon Kardon Soundsticks II
wow dude, those look EPIC, how are they?
OP if you are looking for a 5.1 setup I have a set of Logitech G51s I will be selling very soon after I get my M-audios
selling for cheap
Looks shouldn't matter if you're looking for sound quality.
I personally use the Audioengine A2 w/ speaker stands.
Originally Posted by kow_ciller View Post
Klipsch promedia. Look on ebay, I recently scored a set for $60-shipped
this, I got mine for 105 shipped on here
1 - 20 of 35 Posts
