1 - 9 of 9 Posts
PC Enthusiast
Originally Posted by RacWisco View Post
Howdy. Take a look at my build log if you have a moment I have GTX 480s in tri sli and used the Black ice SR1s. Really happy with temps and noise level.
http://www.overclock.net/intel-build...ooled-gtx.html
Just spent 3 hours reading through the entire thread (had other things to do too, so took a while)
was a awesome read! and I really liked your system
definatly the xspc rx for low speed fans. I cool two gtx 260 blacks and an pII on one rx 360 and no problems or noise
Currently I'm running my CPU, motherboard, and my 480s using a single Black Ice GTX360 radiator in a Cosmos S. The 480s load at high 40's C with that setup, so I'd say a GTX360 is enough. But if you need extra cooling, right now I'm in the process of transferring my rig over to a HAF X, putting the GTX360 on top and adding a GTX 120 to the back (single 140 rad won't fit on the back with the 360 on top once you've accounted for fittings). It should turn out pretty good.
Might have a tough time fitting an RX + fans in your HAF X. I have a 360 stealth + fans and it clears the MB by about 5 mm.
1 - 9 of 9 Posts
