1 - 4 of 4 Posts
Hey guys.
I just got a Creative Sound Blaster Zx...
Now I want a set of kick ass headphones.
I dont mind if they have a mic or not, as I can use the mic on the Zx.
But I dont know what to get
Money isnt really an object for the perfect set.
I would really love for surround, either Virtual or not (not sure which is best).
These will be used for Movies, Gaming and Music.
And I was thinking of using the attached Zx mic and headphone (ACM) slot so doesn't need to be wireless, as I will use that as the control unit.
Thanks for any feedback
Have a look at the Ultrasone Pro 650s if you don't need a mic. If you do want a mic then the Sennheiser PC360/350s are great too.
EDIT: The Ultrasone Pro 650s are hard to find, at least here in the UK. If you can't find them then have a look at the beyerdynamic DT990s.
I'd avoid virtual surround, it just sounds horrible. Definitely go with one of the headphones I recommended but if you insist on virtual surround then the AH-D600s are okay. Don't even bother with the Beats
1 - 4 of 4 Posts
